RTV forum PL | NewsGroups PL
Jak rozpoznać podróbki akumulatorów do UPS? Pojemno¶ć woła o pomstę!
Aku do UPS
NOWY TEMAT
elektroda NewsGroups Forum Index - Elektronika Polska - Jak rozpoznać podróbki akumulatorów do UPS? Pojemno¶ć woła o pomstę!
Goto page Previous  1, 2, 3, 4, 5, 6  Next
J.F
Guest
Wed Aug 27, 2025 12:10 pm
On Wed, 27 Aug 2025 12:02:20 +0200, J.F wrote:
no to jeszcze taki jeden mały test ChatGPT:
"-what is pinout of 74HC595
The 74HC595 is an 8-bit shift register with an output latching
capability, commonly used in digital circuits for expanding the number
of output pins when interfacing with microcontrollers. Below is the
pinout for the 74HC595:
Q7' 1 | | 16 VCC
Q7 2 | | 15 Q6
Q6 3 | | 14 Q5
Q5 4 | | 13 Q4
Q4 5 | | 12 Q3
Q3 6 | | 11 Q2
Q2 7 | | 10 Q1
Q1 8 | | 9 SER
Pin Description:
Pin 1 (Q7'): Serial Out - The output for the last bit of the shift
register.
Pin 2 (Q7): Output 7 - The first output pin for bit 7.
Pin 3 (Q6): Output 6 - Output for bit 6.
Pin 4 (Q5): Output 5 - Output for bit 5.
Pin 5 (Q4): Output 4 - Output for bit 4.
Pin 6 (Q3): Output 3 - Output for bit 3.
Pin 7 (Q2): Output 2 - Output for bit 2.
Pin 8 (Q1): Output 1 - Output for bit 1.
Pin 9 (SER): Serial Input - The input for the first bit of data to
be shifted into the register.
Pin 10 (RCLK): Register Clock - Used to latch the data present at
the outputs.
Pin 11 (SRCLK): Shift Register Clock - Used for shifting data into
the register.
Pin 12 (OE): Output Enable - Active low, when low, the outputs are
enabled.
Pin 13 (MR): Master Reset - Active low, resets the shift register
and outputs to 0 when low.
Pin 14 (VCC): Supply Voltage - Positive power supply.
Pin 15 (GND): Ground - Connects to the negative power supply."
No ... prawie dobrze. Prawie czyni różnicę :-)
https://eduinf.waw.pl/inf/prg/010_uc/74595.php
I jak± tu ocenę dać uczniowi, który by tak odpowiedział?
1 czy 2 ? Bo chyba nie 3 ?
J.
Janusz
Guest
Wed Aug 27, 2025 1:15 pm
W dniu 27.08.2025 o 09:58, Jarosław Sokołowski pisze:
Quote:
Pan Janusz napisał:
Co by im wła¶ciwie szkodziło, żeby z ołowiu w kulkach (dzisiejsza
cena giełdowa 1999,78 USD/tona) zrobić co¶ płaskiego i zamotować
do wnętrza akumulatora?
Płyty s± lżejsze bo nie s± z czystego ołowiu no i produkcja ich
kosztuje, a tak dodaj± trochę balastu i jest taniej.
Ale ołów fałszować ołowiem?! Przyznam, że rozbawiła mnie ta opowie¶ć.
To tak jak z tymi, co ukradli cysternę spiritusu, alkohol sprzedali,
a pieni±dze przepili. Produkcja płyt kosztuje, i to kosztuje więcej,
gdy płyty s± cieńsze. Precyzję i bardziej zaawansowan± technologię
musz± (z nawi±zk±) rekompensować mniejsze koszty materiału. Potem
cały ten zaoszczędzony materiał dosypać w kulkach do ¶rodka?
Też tego nie rozumiem, ale podobno tak bywa, w każdym razie kombinuj± z
płytami
w efekcie czego te akumulatory maj± się nijak do oryginałów które wkłada
producent do ups-ów, ja to ćwiczyłem z APC Smart i CSB czy CBS ( jako¶
tak bo to juz kupę lat minęło) , niby firmowe, oryginalne a miały połowę
krótsz± żywotno¶ć niż nowe z upsami. Sam ich nie rozbierałem więc nie
wiem co było w ¶rodku ale czytałem na forach
że było wszystko co odpowiednio ciężkie z ołowiem wł±cznie.
No ale moje jako¶ chodziły chociaż wyraĽnie krócej, ale to co Mirek
opisał jest już trudne do zrozumienia bo nawet największy paĽdzierz
kupiony w sklepie za rogiem czyli najtańszy aku 12V7.2Ah co¶ tam trzymał
i tak± żarówkę 12V/5A prawie godzinę ¶wiecił as nie parę minut jak On
opisał.
Janusz
J.F
Guest
Wed Aug 27, 2025 1:31 pm
On Wed, 27 Aug 2025 11:26:18 +0200, …Çťxá´‰“’Âí íí í wrote:
Quote:
W dniu 27.08.2025 o 11:19, Tomasz Gorbaczuk pisze:
I to by by‚o na tyle kwestii chatgpt.
Wyja›nienia Chata:
Bo pytania z sugestiÄ… czy z tezÄ… nie sÄ… w‚a›ciwe dla GPT Smile
Te sprbowa‚em ale bez sugestii i tezy na zasadzie odpytywania.
https://g.co/gemini/share/1aa1b7a221a3
Tylko tak "bez sugestii" to moe wywalić d‚uuugÄ… listÄ™ incydentw z
ca‚ego ›wiata.
A nas (w zupe‚nie innej dyskusji) interesowa‚o, czy po 1945 polskie
lotnictwo w ogle co› zestrzeli‚o?
Chyba tylko jaki› rodakw "uciekajÄ…cych na Zachd".
SzczÄ™›liwie nie mieli›my wojny, to i nie trzeba by‚o strzelać.
J.
J.F
Guest
Wed Aug 27, 2025 1:39 pm
On Wed, 27 Aug 2025 11:14:29 +0200, …Çťxá´‰“’Âí íí í wrote:
Quote:
W dniu 27.08.2025 o 10:15, J.F pisze:
Fakt, e te moje stare wykazywa‚y wzrost rezystancji, a moe i korozjÄ™
po‚Ä…cze„.
Jakbym mia‚ gdzie wyrzucic, to moe zrobi‚bym sekcjÄ™.
I co by Ci to da‚o? GPT nie chce Ci siÄ™ odpalić ale stare akumulatory
chcesz penetrować?
No jak widzisz - nie bardzo mi siÄ™ chce.
Ale jakbym spenetrowa‚, to czegos bym siÄ™ dowiedzia‚.
I co by› zrobi‚ z tÄ… wiedzÄ… przy zmar‚ym akumulatorze?
przy zmar‚ym nic, ale moe by pomog‚o przy nastÄ™pnym.
Choć w sumie ... nic nie mogę zrobić.
Chyba, ebym tak nowy UPS kupi‚.
No i oczywiscie mogÄ™ zmienic producenta akumulatora :-)
Quote:
Wie co pisze, czy pisze co wie ? :-P
Skoro przez ostatnie tysiÄ…c lat nie uda‚o Ci siÄ™ zapanować nad spacjÄ…
przed pytajnikiem, to raczej nie rokuje, e jeste› jeszcze rozwojowy Smile
Ale w miÄ™dzyczasie zyska‚em ›wietny argument:
nie umiesz, chamie, po francusku :-P
Quote:
Inna sprawa, e GPT to dopiero preludium przed podjęciem decyzji w
poszukiwaniu "prawdy" a prawda jest taka, e podwyszona temperatura
niszczy akumulatory z powodu zwiększonej reakcji chemicznej Smile GPT Ci
I co ta zwiÄ™kszona reaktywno›Ä‡ reaguje ?
Quote:
nie naprawi takiego akumulatora ale pozwoli zrozumieć problem lepiej ni
be‚kot jakiego› "mÄ…drali" na YT Smile
No nie wiem - jak na mj gust, to te rne czaty więcej zamieszania
wprowadzajÄ…, ni poytku.
I w dodatku nie potrafiÄ… siÄ™ przyznac do niewiedzy - nie wie,
ale skomponuje odpowied, i to w dodatku "sensownie wyglÄ…dajÄ…cÄ…".
J.
x
Guest
Wed Aug 27, 2025 2:03 pm
W dniu 27.08.2025 o 13:31, J.F pisze:
Quote:
I to by było na tyle kwestii chatgpt.
Wyja¶nienia Chata:
Bo pytania z sugesti± czy z tez± nie s± wła¶ciwe dla GPT Smile
Też spróbowałem ale bez sugestii i tezy na zasadzie odpytywania.
Tylko tak "bez sugestii" to może wywalić dłuuug± listę incydentów z
całego ¶wiata.
Nie. Wystarczy zawężać kr±g, co wykazałem, niczego nie sugeruj±c.>
Quote:
A nas (w zupełnie innej dyskusji) interesowało, czy po 1945 polskie
lotnictwo w ogóle co¶ zestrzeliło?
Wychodzi że nie w sensie że może i był "friendly fire" ale nie, że było
to specjalne. Takie rzeczy się zdarzaj± na wojnie.
Pixel
Albo PiS albo Polska
x
Guest
Wed Aug 27, 2025 2:13 pm
W dniu 27.08.2025 o 13:39, J.F pisze:
Quote:
nie naprawi takiego akumulatora ale pozwoli zrozumieć problem lepiej niż
bełkot jakiego¶ "m±drali" na YT :)
No nie wiem - jak na mój gust, to te różne czaty więcej zamieszania
wprowadzaj±, niż pożytku.
I w dodatku nie potrafi± się przyznac do niewiedzy - nie wie,
ale skomponuje odpowiedĽ, i to w dodatku "sensownie wygl±daj±c±".
To też zależy od mentalno¶ci użytkownika. Masz mentalno¶ć PiSiora, który
uważa że się nigdy nie myli ale ci±gle popełnia błędy, często te same.
Podobnie z podatno¶ci± na manipulacje. Zdarzyło mi się, że GPT kłócił
się ze mn± nie raz, więc sprawdziłem inne Ľródła w temacie i okazało
się, ze GPT miał rację Smile Inna sprawa, że nie używam GPT do
"wszystkiego" ale zauważyłem, że je¶li pytanie zawiera wiele szczegółów
i jest precyzyjne, bez sugestii i tezy to odpowiedĽ jest równie
precyzyjna i na 99% prawidłowa. Ten jeden procent zostawiam sobie jako
furtkę czy niedowierzanie i je¶li mam w±tpliwo¶ci to sprawdzam u Ľródeł,
je¶li takie s±.
Pixel
J.F
Guest
Wed Aug 27, 2025 5:35 pm
be‚kot jakiego› "mÄ…drali" na YT :)
To te zaley od mentalno›ci uytkownika. Masz mentalno›Ä‡ PiSiora, ktry
uwaa e siÄ™ nigdy nie myli ale ciÄ…gle pope‚nia b‚Ä™dy, czÄ™sto te same.
Jak w jakims temacie co› wiem, to albo wiem, albo co najmniej wydaje
mi siÄ™, e wiem :-)
I tam, gdzie cos wiem, to mogę ocenić co on pisze.
A tam, gdzie nie wiem, to nie mogÄ™, wiÄ™c by‚bym podatny na
manipulacjÄ™ z jego strony :-)
Quote:
Podobnie z podatno›ciÄ… na manipulacje. Zdarzy‚o mi siÄ™, e GPT k‚ci‚
siÄ™ ze mnÄ… nie raz, wiÄ™c sprawdzi‚em inne rd‚a w temacie i okaza‚o
siÄ™, ze GPT mia‚ racjÄ™ Smile Inna sprawa, e nie uywam GPT do
"wszystkiego" ale zauway‚em, e je›li pytanie zawiera wiele szczeg‚w
i jest precyzyjne, bez sugestii i tezy to odpowied jest rwnie
precyzyjna i na 99% prawid‚owa. Ten jeden procent zostawiam sobie jako
furtkÄ™ czy niedowierzanie i je›li mam wÄ…tpliwo›ci to sprawdzam u rde‚,
je›li takie sÄ….
No to ja go rzadko uywam, poza tym jest kilka innych podobnych,
ale jak temat jest wany - to zawsze sprawdzam.
I na mj gust, to w szczeg‚ach myli siÄ™ bardzo czÄ™sto.
J.
J.F
Guest
Wed Aug 27, 2025 5:46 pm
Wyja›nienia Chata:
ca‚ego ›wiata.
Nie. Wystarczy zawÄ™ać krÄ…g, co wykaza‚em, niczego nie sugerujÄ…c.
Wychodzi e nie w sensie e moe i by‚ "friendly fire" ale nie, e by‚o
to specjalne. Takie rzeczy siÄ™ zdarzajÄ… na wojnie.
Ale takich friendly fire na wojnie by‚o sporo.
Te ameryka„skie w miarÄ™ dobrze udokumentowane, to je znajdzie.
I albo CiÄ™ zarzuci ca‚Ä… listÄ… przypadkw, a nas interesujÄ… te polskie,
albo odpowie na pytanie: Tak, zdarza‚y siÄ™. Nie prosi‚e› o listÄ™ :-)
I moe jest nauczony dodać parÄ™ waniejszych przyk‚adw, ale skoro nie
wszystkie, to nie wiesz, czy polskich nie by‚o, czy tylko nie by‚y
wystarczajÄ…co wane.
A pisze to tak jako› niepewnie, e ja bym to sprawdzi‚ co pisze o
Sycylii.
J.
x
Guest
Wed Aug 27, 2025 8:44 pm
W dniu 27.08.2025 o 17:46, J.F pisze:
Ale takich friendly fire na wojnie było sporo.
Te amerykańskie w miarę dobrze udokumentowane, to je znajdzie.
I albo Cię zarzuci cał± list± przypadków, a nas interesuj± te polskie,
albo odpowie na pytanie: Tak, zdarzały się. Nie prosiłe¶ o listę :-)
I może jest nauczony dodać parę ważniejszych przykładów, ale skoro nie
wszystkie, to nie wiesz, czy polskich nie było, czy tylko nie były
wystarczaj±co ważne.
Ale widać wyraĽnie, że z góry zakładasz, że GPT chce co¶ przed Tob±
ukryć jako "niewygodne", co bardzo wiele osób zarzuca GPT. I nie jest to
'wina" GPT ale mentalno¶ci osoby zadaj±cej pytanie.Ten problem nie
istnieje, je¶li zadasz odpowiednie zapytanie lub pytania pomocnicze.
OK, kawałów o Żydach nie chce opowiadać ale o Polakach ma spory zbiór :D
Pixel
Mirek
Guest
Wed Aug 27, 2025 9:26 pm
W dniu 27.08.2025 o 09:28, J.F pisze:
Quote:
Ja zrozumiałem, że przepracował kilka miesięcy w UPS, i stracił
pojemo¶ć. I Mirek opisuje testy obecne.
Wgl±da na to, że dokładnie 8 miesięcy i trudno to nazwać prac± - one po
prostu stały sobie pod napięciem standby w chłodnym miejscu, zaników
napięcia do tej pory nie było.
Nie wiem jak± pojemno¶ć miały na pocz±tku - nie były sprawdzane (nowe to
nowe) i to jest bł±d. Mam tester "pojemno¶ci", którego awarię zreszt± tu
opisywałem, ale on nawet na tych rzeczonych pokazuje 7,5Ah więc się nie
nadaje. Tester jest "sprawny" w tym sensie, że na nowych HR1234W
pokazuje 9Ah, na nowych 5Ah pokazuje 7Ah, na nowych 2,3Ah pokazuje 2,5Ah.
Aktualnie klecimy jaki¶ układ pomiarowy żeby zmierzyć pojemno¶ć całej
baterii 240V (20 akumulatorów 12V... a s± dwie... w jednym z kilku
ups-ów), bo nikt nie będzie rozdzierał pakietu za każdym razem i
wykonywał długotrwałego (miejmy nadzieję) pomiaru.
Mirek
x
Guest
Wed Aug 27, 2025 11:45 pm
Quote:
Inna sprawa, że GPT to dopiero preludium przed podjęciem decyzji w
poszukiwaniu "prawdy" a prawda jest taka, że podwyższona temperatura
I co ta zwiększona reaktywno¶ć reaguje ?
Widać nadal nie rozumiesz. Spróbuj jednak ugotować jajko w temperaturze
"pokojowej" zakładaj±c poziom 0m NPM :)
Pixel
J.F
Guest
Thu Aug 28, 2025 8:56 am
Rozumiem, e jest zwiÄ™kszona reaktywno›Ä‡, ale co atakuje?
Quote:
Sprbuj jednak ugotować jajko w temperaturze
"pokojowej" zak‚adajÄ…c poziom 0m NPM Smile
Jajko się powinno "ugotować" w temperaturze .. nie wiem - 50-60
stopni?
100C jajku nie potrzebne.
A ciekawe, ile ma akumlator w samochodzie.
Np w czasie postoju z w‚Ä…czonym silnikiem,
albo po parkowaniu w gorÄ…cy, s‚oneczny dzie„,
albo po takim parkowaniu, jak to samochd z akumulatorem w kabinie.
J.
J.F
Guest
Thu Aug 28, 2025 10:28 am
U mnie też zaników jak na lekarstwo, a 2-4 lata, i aku do wyrzucenia.
Widać stanie pod napięciem im szkodzi :-)
Rozładowanie aku ołowiowego mu szkodzi, więc ja też nie testuję.
No to ciekawe co on mierzy ...
Przy czym:
-taki miernik pojemnosci może być w miarę prosty i dokładny, ale
pomiar będzie trwał ... 10h.
-aku 7Ah to teoretycznie powienie dawać 0.7A przez 10h, a może 0.35A
przez 20h, bo im większy pr±d, tym mniejsza pojemno¶ć.
-ale jak UPS bierze choć 300W, to mamy 25A z 12V aku. I pojemno¶ć
spada bardzo.
Być może one nie tyle straciły pojemno¶ć, co wzrosła rezystancja
wewnętrzna, spadło napięcie i UPS się szybko sam wył±cza.
Farelka i zegar elektryczny :-)
Ale ... BMS tam masz? Bo pewnie rzeczywiste pojemno¶ci nie s± równe,
i niektóre aku s± rozładowywane ponad miarę.
No ale te, jak piszesz, to wcale nie były rozładowywane.
J,
J.F
Guest
Thu Aug 28, 2025 11:10 am
Ale widać wyranie, e z gry zak‚adasz, e GPT chce co› przed TobÄ…
ukryć jako "niewygodne", co bardzo wiele osb zarzuca GPT. I nie jest to
Nie, ja zarzucam, e nieprawdÄ™ wypisuje.
Quote:
'wina" GPT ale mentalno›ci osoby zadajÄ…cej pytanie.Ten problem nie
istnieje, je›li zadasz odpowiednie zapytanie lub pytania pomocnicze.
No ale zapyta‚es Gemini (bo to jednak nie ChatGPT)
"czy podczas drugiej wojny ›wiatowej dosz‚o do zestrzelenia
ameryka„skiego samolotu omy‚kowo?"
Więc odpowiedzieć moe na to trojako:
-Tak. I tyle, bo dosz‚o, nie raz.
-Tak, i podać pe‚nÄ… listÄ™ zdarze„,
-Tak, i podac jakie› przyk‚ady.
Czy ja mam z‚Ä… mentalno›Ä‡, ze uwaam i "przyk‚ady" to nie jest
pe‚na lista? Czy to ty masz z‚Ä… mentalno›Ä‡, i z gry zak‚adasz, e
chce ukryć co› niewygodnego ? :-)
Dalej dopytywa‚e›, i chwa‚a Gemini, e pamiÄ™ta‚ konwersacjÄ™.
Bo co do chatgpt, to nie jestem pewien, skoro
"-kiedy Polska zestrzeli‚a amerykanskiego C-47
Do zdarzenia, w ktrym Polska zestrzeli‚a ameryka„ski samolot C-47,
dosz‚o 7 lutego 1945 roku. Incydent mia‚ miejsce w czasie [...]
-Gdzie dok‚adnie mia‚o miejsce to zdarzenie ?
Aby odpowiedzieć na Twoje pytanie, potrzebowa‚bym wiÄ™cej informacji na
temat konkretnego zdarzenia, o ktrym mwisz. Proszę podaj więcej
szczeg‚w, a postaram siÄ™ pomc!
No prawda, to on mwi‚ o zdarzeniu, nie ja :-)
"-Gdzie dok‚adnie Polska zestrzeli‚a amerykanskiego C-47 ?
Nie ma adnych wiarygodnych informacji ani dokumentacji historycznej
dotyczÄ…cych zestrzelenia ameryka„skiego samolotu C-47 przez PolskÄ™.
do **** z takÄ… pomocÄ… :-)
Ale sprbujmy dzisiaj
"-kiedy Polska zestrzeli‚a amerykanskiego C-47?
Polska nie zestrzeli‚a ameryka„skiego samolotu C-47. Jednak Incydent z
17 wrze›nia 1944 roku, znany jako "Incydent z C-47", mia‚ miejsce, gdy
ameryka„ski samolot transportowy C-47 zosta‚ zestrzelony przez
radzieckie si‚y powietrzne w okolicach Warszawy. By‚ to wynik mylenia
go z samolotem wroga, co by‚o wynikiem napiÄ™tej sytuacji politycznej i
wojskowej w tamtym czasie. Warto zaznaczyć, e incydent ten dotyczy‚
radzieckich si‚, a nie polskich.
Proszę o więcej informacji dotyczących zdarzenia, o ktrym mwisz.
Jakie konkretnie zdarzenie masz na my›li? DziÄ™ki temu bÄ™dÄ™ mg‚ lepiej
pomc w odpowiedzi na Twoje pytanie.
Nie ma adnych udokumentowanych informacji, ktre wskazywa‚yby, e
Polska zestrzeli‚a ameryka„ski samolot C-47. C-47 Skytrain to samolot
transportowy uywany przez wojska ameryka„skie podczas II wojny
›wiatowej i w pniejszych konfliktach. Je›li masz na my›li jaki›
konkretny incydent lub sytuacjÄ™, proszÄ™ podaj wiÄ™cej szczeg‚w. MogÄ™
pomc w znalezieniu odpowiednich informacji.
-skÄ…d wiesz o zestrzeleniu przez PolskÄ™ ameryka„skiego samolotu C-47 ?
Nie mam informacji na temat zestrzelenia przez PolskÄ™ ameryka„skiego
samolotu C-47. Moje dane sÄ… aktualne do padziernika 2023 i nie
zawierajÄ… adnych wiadomo›ci ani informacji na ten temat. Je›li to
zdarzenie mia‚o miejsce lub by‚o przedmiotem dyskusji po tej dacie,
nie bÄ™dÄ™ w stanie dostarczyć dok‚adnych informacji. ProszÄ™ o podanie
dodatkowych szczeg‚w lub kontekstu, a postaram siÄ™ pomc najlepiej,
jak potrafiÄ™.
-skÄ…d wiesz o zestrzeleniu przez ZSRR ameryka„skiego samolotu C-47 ?
Zestrzelenie ameryka„skiego samolotu C-47 przez ZSRR mia‚o miejsce 1
lipca 1952 roku. Samolot ten, znany rwnie jako Dakota, zosta‚
zestrzelony nad Morzem Japo„skim. ZSRR twierdzi‚, e samolot naruszy‚
przestrze„ powietrznÄ…, co by‚o czÄ™›ciÄ… szerszego kontekstu zimnej
wojny i napięć między ZSRR a [...]
Zestrzelenie ameryka„skiego samolotu C-47 przez ZSRR mia‚o miejsce 13
lipca 1952 roku. Dowdztwo radzieckie zestrzeli‚o ten samolot, ktry
rzekomo naruszy‚ przestrze„ powietrznÄ… ZSRR. Wydarzenie to sta‚o siÄ™
czÄ™›ciÄ… szerszego kontekstu zimnej wojny, w ktrym napiÄ™cia miÄ™dzy
Stanami Zjednoczonymi a ZSRR by‚y na porzÄ…dku dziennym. Informacje na
temat tych wydarze„ sÄ… dostÄ™pne w rnych rd‚ach historycznych,
dokumentach wojskowych oraz archiwach pa„stwowych. Wiele z nich mona
znaleć w publikacjach dotyczących historii zimnej wojny.
-Gdzie mogÄ™ przeczytać o zestrzeleniu ameryka„skiego samolotu C-47
przez ZSRR?
lipca 1950 roku i jest mniej znanym wydarzeniem zimnej wojny. Aby
przeczytać więcej na ten temat, moesz skorzystać z następujących
rde‚:
1. Ksiąki historyczne – Szukaj publikacji dotyczących zimnej wojny,
konfliktu w Korei lub stosunkw ameryka„sko-radzieckich. KsiÄ…ki takie
jak „The Korean War” autorstwa Bruce'a Cummina lub „Cold War: A New
History” autorstwa Johna Lewis Gaddisa mogą zawierać informacje na ten
temat.
2. Artyku‚y naukowe – Sprawd bazy danych akademickie, takie jak
JSTOR czy Google Scholar, gdzie mona znaleć artyku‚y omawiajÄ…ce ten
incydent w kontek›cie historycznym.
3. Strony internetowe i portale historyczne – Wiele historycznych
portali, takich jak History.com lub O›rodkw Bada„ Systemw
Totalitarnych, moe mieć artyku‚y po›wiÄ™cone zimnej wojnie i
incydentom takim jak zestrzelenie C-47.
4. Encyklopedie online – Wikipedia moe być dobrym punktem wyj›cia
do zebrania podstawowych informacji oraz odnalezienia rde‚, ktre
mona zg‚Ä™bić.
5. Wydarzenia w wiadomo›ciach – Archiwa najwiÄ™kszych agencji
informacyjnych, takich jak AP czy Reuters, mogą take zawierać
historyczne artyku‚y dotyczÄ…ce tego incydentu.
Warto rwnie zwrcić uwagę na literaturę dotyczącą konkretnych
wydarze„ zwiÄ…zanych z zimnÄ… wojnÄ…, ktra moe zawierać opisy i analizy
takich incydentw."
Quote:
OK, kawa‚w o ydach nie chce opowiadać ale o Polakach ma spory zbir Very Happy
I to ty mowisz, e niektrzy majÄ… takÄ… podejrzanÄ… mentalno›Ä‡ :-)
"-jaki jest najlepszy kawa‚ o ydach?
Humor zwiÄ…zany z konkretnymi grupami etnicznymi lub religijnymi, w tym
ydami, moe być delikatny i ‚atwo przekszta‚cić siÄ™ w co›
obraliwego. Wane jest, aby podchodzić do takich tematw z szacunkiem
i wraliwo›ciÄ…. Je›li szukasz dowcipw, mogÄ™ zaproponować co›
neutralnego lub o oglnym charakterze. Co my›lisz?
-jaki jest najlepszy kawa‚ ydowski?
Humor ydowski ma d‚ugÄ… tradycjÄ™ i czÄ™sto ‚Ä…czy w sobie ciekawe
spostrzeenia na temat ycia, relacji międzyludzkich czy codziennych
sytuacji. Oto kawa‚, ktry pasuje do tej tradycji:
Mwi rabin do swojego wiernego:
Synu, za co siÄ™ modlisz?
O wielkie bogactwo, rabinie!
A dlaczego?
eby mc dawać na biednych.
Wiesz, synu, w takim razie powiniene› modlić siÄ™, eby być
biednym!
Humor ydowski często polega na autoironicznych obserwacjach, więc
jest wiele ›wietnych kawa‚w, ktre moesz poznać. Je›li chcesz
us‚yszeć wiÄ™cej, daj znać!
-what is the best joke about Jews ?
Humor can be a sensitive topic, especially when it involves cultural
or religious groups. It's important to approach such subjects with
respect and sensitivity. Here's a light-hearted joke that celebrates
Jewish culture without being ofensive:
"Why do Jewish mothers make great detectives? Because they always find
the missing 'meshugas' (craziness) in every situation!"
Remember, the best jokes are those that bring people together rather
than potentially isolate or offend anyone.
-what is the best jewish joke?
Humor can be quite subjective, but here’s a classic Jewish joke that
many find amusing:
Two elderly Jewish men, Abe and Sol, are sitting on a park bench,
reminiscing about their lives.
Abe says, "You know, Sol, I’ve had a really nice life. I’ve got a
wonderful wife, children, grandchildren, and even great-grandchildren.
I feel blessed."
Sol replies, "That’s wonderful, Abe. I’ve had a good life too, but I
don't have any great-grandchildren."
Abe thinks for a moment and says, "Well, maybe that's because you keep
forgetting to tell them the right stories!"
It’s a light-hearted reminder of the value of sharing our stories and
traditions!
J.
J.F
Guest
Thu Aug 28, 2025 1:42 pm
On Tue, 26 Aug 2025 18:30:43 +0200, Jarosław Sokołowski wrote:
Quote:
Pan Janusz przejrzał knowania Chińczyków:
A nie wysechł? Te moje waż± tyle co w karcie katalogowej +/-1g.
Wycwanili się i sypi± piasek albo kulki ołowiane żeby waga się zgadzała.
Co by im wła¶ciwie szkodziło, żeby z ołowiu w kulkach (dzisiejsza cena
giełdowa 1999,78 USD/tona) zrobić co¶ płaskiego i zamotować do wnętrza
akumulatora? Pisek to rozumiem, co¶ jeszcze o kawałkach szkła ludzie
mówili.
A propos - wła¶nie mi podrzuciło:
https://www.youtube.com/shorts/sAkNrITrAnQ
J.
NOWY TEMAT
