Goto page Previous 1, 2, 3, 4 Next
Cezar
Guest
Mon May 15, 2023 5:43 pm
On 15/05/2023 15:52, J.F wrote:
Quote:
On Mon, 15 May 2023 08:56:39 +0100, Cezar wrote:
On 15/05/2023 08:45, Robert Wańkowski wrote:
S± białe diody LED, ale bez luminoforu?
RGB?
A tak swoj± drog± - czy z faktu, ze RGB nie s± stosowane, nalezy
wnioskować, że luminofor ma większ± sprawnosć?
Tzn sa stosowane, ale tam, gdzie sie od razu daje zmianę kolorów.
J.
ChatGPT:
White LEDs are typically made using a blue LED with a phosphor emitter
instead of RGB LEDs due to several reasons:
Efficiency: Blue LEDs have higher efficiency compared to green and red
LEDs. They can convert electrical energy into light energy more
effectively, resulting in higher luminous efficiency. By using a blue
LED as the primary light source, white LEDs can achieve greater overall
efficiency.
Cost: Manufacturing processes for blue LEDs have advanced significantly,
making them more cost-effective to produce compared to RGB LEDs. Blue
LEDs are widely used in various applications, resulting in economies of
scale and lower production costs.
Color quality: Blue LEDs combined with a phosphor coating can provide a
high-quality white light. The phosphor converts part of the blue light
emitted by the LED into yellow light, resulting in a combination of blue
and yellow light that appears white to the human eye. This method can
produce a more uniform and pleasing white light compared to the additive
color mixing of RGB LEDs.
Stability and longevity: Blue LEDs have proven to be more stable and
longer-lasting than green and red LEDs. The blue light is less prone to
degradation over time, allowing white LEDs to maintain their color
temperature and brightness more effectively.
While RGB LEDs can be used to create white light by combining red,
green, and blue light, they often have lower efficiency, higher cost,
and poorer color quality compared to blue LED-based white LEDs. RGB LEDs
are commonly used in applications where color-changing capabilities or
specific color output is required, such as in decorative lighting or
displays.
alojzy nieborak
Guest
Mon May 15, 2023 5:48 pm
RGB?
Trza sprawdzić jak± poszczególne R, G, B maj± sprawno¶ć.
I co wa¶ciwie siedzi jako pierwotne Ľródło UV a białym LED.
Może nie UV tylko 450 nm. UV maj± nędzn± sprawno¶ć, ale 445nm
ma sprawno¶ć już całkiem całkiem.
Na czuja/intuicyjnie w białych siedzi 445-450nm, a nie żadne UV.
https://tinyurl.com/2p9xpmhm
Sprawno¶ć:
https://tinyurl.com/4r3u8u5x
RoMan Mandziejewicz
Guest
Mon May 15, 2023 8:57 pm
Hello Robert,
Monday, May 15, 2023, 9:45:04 AM, you wrote:
Tak. Niektóre diody Zenera ¶wiec± słabym, białym ¶wiatłem. Ale s±
bezużyteczne ze względu na skrajnie nisk± sprawno¶ć.
Poza tym - s± diody RGB.
Best regards,
RoMan
RoMan Mandziejewicz
Guest
Mon May 15, 2023 8:58 pm
Hello Robert,
Monday, May 15, 2023, 10:22:33 AM, you wrote:
Robert
RGB?
Nie, czy jest taka w której sama struktura ¶wieci ¶wiatłem białym?
Klasyczne LED z samej zasady nie mog± ¶wiecić białym ¶wiatłem.
Best regards,
RoMan
RoMan Mandziejewicz
Guest
Mon May 15, 2023 9:00 pm
Hello Cezar,
Monday, May 15, 2023, 11:26:33 AM, you wrote:
Quote:
To nadal fotoluminescencja.
Best regards,
RoMan
RoMan Mandziejewicz
Guest
Mon May 15, 2023 9:03 pm
Hello J.F,
Monday, May 15, 2023, 4:52:53 PM, you wrote:
RGB?
Chodzi o CRI - RGB maj± dziurawe spektrum. dlatego robi się RGBW...
Best regards,
RoMan
J.F
Guest
Tue May 16, 2023 9:12 am
RGB?
ChatGPT:
efficiency.
Jak widac to podejrzewam, ale niebieski foton wymaga wyzszej energii i
wyzszego napiecia i zamienia sie potem na foton o nizszej energii ...
brzmi jak strata.
Wow.
Ale inne kolory tez były masowo używane.
Hm ... a wydawałoby sie, ze diody Led poł±czone szeregowo powinny
dawac podobne ilosci swiatla ...
Hm. Diody RYG malej mocy swiec± dekadami.
W białych pojawiło sie "lumen maintenance".
RGB zamiast jednej B, to moze i wiekszy koszt, ale jak w "żarówce"
jest diod i tak 10 ...
Taa, szczegolnie jak sie pisze, ze luminofor daje żółty kolor.
Współczesnie daje juz mieszankę ...
J.
Robert Wańkowski
Guest
Tue May 16, 2023 9:24 am
W dniu 15.05.2023 o 20:57, RoMan Mandziejewicz pisze:
Quote:
Hello Robert,
A możesz podać przykładow±? ¦wieci w stanie przewodzenia czy przebicia?
Robert
J.F
Guest
Tue May 16, 2023 9:36 am
On Mon, 15 May 2023 21:03:32 +0200, RoMan Mandziejewicz wrote:
Quote:
Hello J.F,
RGB?
Hm, to W to nie będzie dziurawe?
Teraz jest dosc szerokie, ale kiedys ponoc było tylko Y z luminoforu
J.
RoMan Mandziejewicz
Guest
Tue May 16, 2023 2:01 pm
Hello Robert,
Oczywi¶cie w kierunku wstecznym, na napięciu Zenera. Konkretów nie
podam, bo lata minęły, kiedy się tym bawiłem. Dużo jest w tym
przypadkowo¶ci, niestety. I jest to naprawdę żało¶nie słabe ¶wiatło.
Best regards,
RoMan
Robert Wańkowski
Guest
Tue May 16, 2023 2:21 pm
W dniu 16.05.2023 o 14:01, RoMan Mandziejewicz pisze:
Quote:
Hello Robert,
Ale odpiłowywałe¶ obudowę TO-18 czy te szklane?
Robert
LordBluzg®🇵🇱
Guest
Tue May 16, 2023 3:05 pm
J.F
Guest
Tue May 16, 2023 4:13 pm
On Tue, 16 May 2023 15:05:26 +0200, LordBluzgÂ®í Ľí·µí Ľí·± wrote:
Quote:
W dniu 16.05.2023 o 09:12, J.F pisze:
A tak swojÄ… drogÄ… - czy z faktu, ze RGB nie sÄ… stosowane, nalezy
wnioskować, że luminofor ma większą sprawnosć?
Tzn sa stosowane, ale tam, gdzie sie od razu daje zmianÄ™ kolorĂłw.
ChatGPT:
efficiency.
brzmi jak strata.
Mało znaczna, znaczy 10% straty przy MEGAMOCY w sensie widoczności.
Teoretycznie to calkiem sporo mocy, jak niebieski przerabiasz na
czerwony.
Quote:
Na działce wystawiłem sobie taką niebieską diodę migającą.
Chciałem uzyskać efekt "prewencji" w sensie, że ma ją być widać z 50m,
kiedy mam włączony alarm.
Widać ją z KILOMETRA w linii prostej/w nocy. Sąsiad, który mieszka
właśnie kilometr dalej, kiedyś mnie zaczepił...co tam mam bo mu mruga w
pokoju przez szybÄ™
Przyszedł w dzień na działkę specjalnie, żeby
zobaczyć i oczywiście nie uwierzył, pomimo iż widział tą diodę z 10cm.
Poszedłem w nocy i rzeczywiscie widać ją z kilometra
Fakt - "walÄ… po oczach" te niebieskie diody, tylko tez ciekaw jestem
dlaczego. To nie jest kolor, przy ktorym oko jest najczulsze
(przy żółto-zielonym jest), czyli wychodziłoby, ze wydajnosc LED
wielka ... ale inne kolory tez sie chyba przez te 2 wieki poprawiły ?
J.
RoMan Mandziejewicz
Guest
Tue May 16, 2023 4:36 pm
Hello Robert,
Szklane oczywi¶cie - wiedziałem, że zjawisko istnieje ale osobi¶cie
zaobserwowałem zupełnie przypadkowo, gdy uruchamiałem zasilacz
indukcyjny do lampy LED. Zgasiłem ¶wiatło, wł±czyłem zasilacz ale
lampa była jeszcze za daleko i zobaczyłem białe ¶wiatełko w zasilaczu
- jarzyła się Zenerka. Uprzedzaj±c - nie była przeci±żona.
Best regards,
RoMan
LordBluzg®🇵🇱
Guest
Tue May 16, 2023 5:39 pm
