RTV forum PL | NewsGroups PL
Jak dostosować kod termometru cyfrowego do mikrokontrolera ATmega8?
Co zmienić?
NOWY TEMAT
elektroda NewsGroups Forum Index - Elektronika Polska - Jak dostosować kod termometru cyfrowego do mikrokontrolera ATmega8?
Gibol
Guest
Thu Nov 23, 2006 10:33 pm
Co zmienić w programie żeby chulało mi pod ATmega8 (akurat taki mam na
stanie)
thermo.c
Digital Thermometer -55C to +125C
AVR 90S2313 & DS1820
Copyright 2001 by Wichit Sirichote
#include <90s2313.h>
#include <math.h>
// 1 Wire Bus functions
#asm
.equ __w1_port=0x12
.equ __w1_bit=6
#endasm
#include <1wire.h>
// DS1820 temperature sensor functions
#include <ds1820.h>
// Declare your global variables here
unsigned char tick,i,digit;
unsigned char heat[4];
unsigned int xtimer1;
int temp,T,X1,X2,X3,X4,X5; // signed number for negative and positve
temperature manipulating
char key;
unsigned char convert[10] =
{0x3F,0x06,0xdb,0xcf,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
#define segment PORTB
#define LED_digit PORTD
// converts 16-bit data in T to display buffer for both negative and
positive reading
void heatToBuffer()
if(T<0){
heat[3] = 0x40; // if negative, put -
heat[0] = 0x39; // C
T = abs(T); // get only amplitude
heat[1] = convert[T%10];
heat[2] = convert[T/10];
if (heat[2] == 0x3f)
heat[2] = 0; // off msd
else
heat[3] = convert[T/100];
temp = T%100;
heat[1] = convert[temp%10];
heat[2] = convert[temp/10];
// off msd
if (heat[3] == 0x3f)
heat[3] = 0;
if(heat[2] == 0x3f)
heat[2] = 0;
LPF() // performs five-point moving average
X5=X4;
X4=X3;
X3=X2;
X2=X1;
X1= T;
T = (X1+X2+X3+X4+X5)/5;
read_temp()
if(++xtimer1 >=5)
xtimer1 = 0;
segment = 0xff;
T = ds1820_temperature_10(0)/10; // read DS1820 every 5 sec.
LPF(); // enter filter
heatToBuffer(); // convert it
// Timer 0 overflow interrupt service routine
// timer interrupt every 1/15 sec provides foreground task to be run
periodically.
interrupt [TIM0_OVF] void timer0_ovf_isr(void)
switch (++tick){
case 15: tick = 0;
read_temp(); //second_task();
void scanLED() /* scan 4-digit LED and 4-key switch, if key pressed key =
0-3
else key = -1 */
// adapted from 89C2051 project if needs scan key, find one bit input port
char i;
digit = 0x20;
key = -1;
for( i = 0; i < 4; i++) /* 4-DIGIT scanning */
LED_digit = ~digit; /* send complement[digit] */
segment = ~heat[i]; /* send complement[segment] */
delay_ms(1); /* delay a while */
segment = 0xff; /* off LED */
// if ((PORTD & 0x10) == 0) /* if key pressed P3.4 became low */
// key = i; /* save key position to key variable */
digit>>=1; /* next digit */
void main(void)
DDRB=0xFF;
PORTB=0x00;
DDRD=0x7F;
PORTD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: 3.906 kHz
// Mode: Output Compare
// OC0 output: Disconnected
TCCR0=0x05;
TCNT0=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x02;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
// 1 Wire Bus initialization
w1_init();
// Global enable interrupts
#asm("sei")
w1_init();
T = 34;
heatToBuffer();
while (1)
scanLED(); // run background task forever
mIrO
Guest
Thu Nov 23, 2006 11:04 pm
Użytkownik "Gibol" napisał w wiadomości
stanie)
Programiste ;P
MSPANC
Pzdr,
mIrO
Gibol
Guest
Thu Nov 23, 2006 11:09 pm
Quote:
Programiste ;P
Mam juz ten projekt na 8051, tylko to nie ma isp i nie che mi sie motać z
programatorem. Znalazlem wiec na tego AVRa tyle ze mam mege 8 i na niej
chciałbym to postawić a moje umiejetnosci programowania sa na poziomie
bardzo początkującym. Mniej wiecej kojaze o co chodzi Razz
mIrO
Guest
Thu Nov 23, 2006 11:20 pm
Quote:
a moje umiejetnosci programowania sa na poziomie bardzo początkującym.
To warto sobie cos w asmie napisac - pozwala na nauczenie sie zasady
dzialania rodziny kontrolerow ;)
Pzdr,
mIrO
Wmak
Guest
Thu Nov 23, 2006 11:41 pm
stanie)
Programiste ;P
MSPANC
I słownik ortograficzny...
Wysłano z serwisu Usenet w portalu Gazeta.pl -> http://www.gazeta.pl/usenet/
Gibol
Guest
Fri Nov 24, 2006 12:06 am
Co zmienić w programie żeby hulało mi pod ATmega8 (akurat taki mam na
stanie)
Programiste ;P
MSPANC
Dobra, dzięki za cenne rady, ale moze jednak ktoś mi powie, czy musze cos
zmieniac oprócz <90s2313.h> ?
Artur M. Piwko
Guest
Fri Nov 24, 2006 12:40 pm
In the darkest hour on Thu, 23 Nov 2006 23:20:06 +0100,
mIrO <miro@spamowi_mowie_nie.pl> screamed:
Mniej wiecej kojaze o co chodzi :P
Szkoda tracić na pisanie w 100% asm czasu.
[ Artur M. Piwko : Pipen : AMP29-RIPE : RLU:100918 : From == Trap! : SIG:212B ]
[ 12:11:58 user up 11170 days, 0:06, 1 user, load average: 0.06, 0.06, 0.06 ]
The butler is innocent.
Robgold
Guest
Fri Nov 24, 2006 1:12 pm
Użytkownik "Gibol" <gibol@skrzynka_w_goglach.com> napisał w wiadomości news:ek56ck$cq7$1@nemesis.news.tpi.pl...
Quote:
Programiste ;P
Napisz sobie to samemu w Bascom'ie. Wieksza radosc bedzie a caly program termometru to zaledwie kilka linijek Smile
mIrO
Guest
Fri Nov 24, 2006 1:27 pm
Użytkownik " Wmak" napisał w wiadomości
stanie)
Programiste ;P
MSPANC
Tego nawet nie zauwazylem Smile
A onegdaj w szkolach nawet wierszyka uczyli, zeby lepiej pisownie takich
wyrazow zapamietac ;)
Pzdr,
mIrO
mIrO
Guest
Fri Nov 24, 2006 1:30 pm
stanie)
Programiste ;P
MSPANC
A onegdaj w szkolach nawet wierszyka takiego uczyli:
Kłopotliwe samo h, Dość szczególną skłonność ma,
lubi hałaśliwe słowa:
hak, harmider, hałasować,
heca, hurmem, hej, hop,
hura, hola, horda, hejnał,
hulać, hasać, halo, hop,
wataha ...
W tych wypadkach się nie wahaj.
Pzdr,
mIrO
Marcin Stanisz
Guest
Sat Nov 25, 2006 6:04 am
Nie każ nam grzebać po manualach procków Wink Znajdź w kodzie fragmenty
zależne od sprzętu (na pierwszy rzut oka inicjalizacja timera i
komparatora, fuse bity też będą inaczej ustawione) i posprawdzaj, czy żeby
osiągnąć opisany w programie efekt nie trzeba przypadkiem wstawić innyh
wartości.
Marcin Stanisz
"A lie will go round the world before the truth has got its boots on"
Terry Pratchett, "Truth"
mIrO
Guest
Mon Nov 27, 2006 7:18 pm
Użytkownik "Artur M. Piwko" napisał w wiadomości
Na pisanie szkoda czasu, na nauke architektury kontrolera wcale.
Pzdr,
mIrO
NOWY TEMAT
